Distribution
Distribution is an EMC function that lets you copy records between properties and revenue centers. You can configure records once within the EMC and distribute the records throughout the enterprise to multiple properties and revenue centers without having to create a record multiple times.
Remote Distribution
Remote distribution enables you to transfer data between two Simphony systems. Both the source and destination systems must be running the same Simphony version and hotfix.
The Importance of Object Numbers
When records are distributed from one location to another, the object number stays the same. Therefore, it is important to configure properties and revenue centers consistently. For example, if object number 11 is Room Charge in one property, it must be Room Charge in all properties. Consider the following sample serving period configuration in revenue center 4:
  • Object Number: 1
  • Default Transaction Page: 41
When distributing this record to revenue center 8, it is created with the object number 1, and there are two possibilities for the default transaction page:
  • If transaction page object number 41 exists in revenue center 8, the serving period's default screen is set to 41.
  • If transaction page object number 41 does not exist in revenue center 8, the default screen is set to 0. This is the standard functionality for all types of distributed records. If the referencing object number does not exist, the value is set to 0.
Distribution based on source, destination, and selected options
The following table describes how records are distributed based on the source record, destination record, and selected distribution options.
Table 3-4 Distribution based on source, destination, and selected options
Record Source Type Record Destination Type Distribute Inherited Records If Destination Record Is Inherited, Create Override Destination Record Created?
Inherited
Inherited
Selected
Selected
Yes
Inherited
Inherited
Selected
Deselected
No
Inherited
Inherited
Deselected
Selected
No
Inherited
Inherited
Deselected
Deselected
No
Inherited
Defined
Selected
N/A
Yes
Inherited
Defined
Deselected
N/A
No
Defined
Inherited
Selected
Selected
Yes
Defined
Inherited
Selected
Deselected
No
Defined
Inherited
Deselected
Selected
Yes
Defined
Inherited
Deselected
Deselected
No
Defined
Defined
Selected
N/A
Yes
Defined
Defined
Deselected
N/A
Yes
