Menu Item Overrides
Use the Menu Item Override indicator to identify hierarchy levels where a menu item definition is configured. To show the indicator, select Map Menu Item Overrides on the search panel before searching.
Override indicators
The Override Indicator column uses the following markers:
  • Up arrow: A definition exists above the current hierarchy level.
  • Down arrow: A definition is overridden below the current hierarchy level.
  • Plus sign: A definition exists at another location, such as a peer or a different zone, that is neither above nor below the current location.
