Searching and Filtering Menu Items
The Menu Item Maintenance module allows you to search for menu items. Typically several thousand menu item records are likely to exist. Searching and filtering allows you to work with only the desired menu item records. By default, no items appear in table view.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
  2. To view all records, click Search without entering search criteria.
    Depending on the number of menu items, this step may take several minutes.
  3. To view specific menu item records, enter information in the relevant search fields, and then click Search.
    Table 17-30 Search Fields
    Field Description
    Record Type
    Select the type of record to find (Menu Item Master, Menu Item Definition, or Menu Item Price). When both a Menu Item Master and a revenue center are selected, Simphony returns only master records with definitions in the selected revenue center.
    Name Search
    Enter the menu item name (partial or full) to search. Only records containing the text in the name field for the specified language are returned. Menu Item Definition and Price searches will look for the text in either the Name 1 or Name 2 fields. Entering Shrimp Cocktail returns the specific record; a family group search on Appetizers returns results more quickly.
    Major Group
    Enter a major group number or a range of major group numbers to include in the search.
    Family Group
    Enter a family group number or a range of family group numbers to include in the search.
    Master Group
    Enter a menu item master group number or a range of master group numbers to include in the search.
    Object Number or Range
    Enter an object number or range of object numbers to include in the search.
    Show Master w/Defs Only
    Select to show only menu item master records that contain one or more definitions for this zone or property. Deselect to show all menu item master records for this level or above.
    Map Menu Item Overrides
    Select to show the Menu Item Override indicator, which allows you to see other locations in the Enterprise where the item is configured. See Menu Item Overrides for information about the indicator. Deselect to exclude the Menu Item Override indicator. As the system needs to check the entire enterprise for the menu item, the search results will take longer to generate. Therefore, set this option only when there is a specific need to see this information.
    Class
    Enter a menu item class or range of menu item classes to include in the search when querying menu item definitions or menu item prices.
    SLU
    Enter a SLU or range of SLUs to include in the search when querying menu item definitions or menu item prices.
    Sales Itemizer
    Enter a sales itemizer or range of sales itemizers to include in the search when querying menu item definitions or menu item prices.
