Preface
Oracle Simphony is an enterprise transaction processing platform used by businesses that vary in size from single unit to global, franchised, multi-unit operations. A Simphony system manages different food and beverage operations models, including:
Table service
Quick service
Fast casual
Bar
Drive-Thru
Concessions
Retail
Purpose
This Configuration Guide provides system administrators instructions to set up Simphony.
Audience
This document is intended for system administrators of Simphony.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony Digital Learning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Oracle Restaurants Learning Subscription.
Revision History
| Date | Description of Change |
June 2026 |
Initial publication. |
