Configuring Discount Bundles
The following table lists the prerequisites for discount bundles.
Table 15-3 Discount Bundle Plug-in Prerequisites
Category Description
Compatibility
The solution is used with Simphony 19.4 or later.
This application is available for Simphony workstations running on the Microsoft Windows® or Oracle Linux for MICROS operating systems. This application is not supported on Android, macOS, or other operating systems.
Menu items that have prompts (for example, Required Condiments) are not supported with discount bundles.
Setup
Configuration of all Simphony settings, including Page Design and nutritional and allergen information, is a manual process. Specific instructions regarding design elements are not included in this section. The implementor of this solution must design and configure screens and buttons based on property and cosmetic preferences.
