EMC – Configure the Data Extensions
Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
Double-click the discount and toggle to form view.
In the Data Extensions tab, select DiscountBundle.
Configure DiscountBundleItems as a comma-separated list of menu item object numbers for the menu items to be added to the check before the discount is applied.
Figure 15-10 Data Extensions
Click Save.
The discount bundle extension application works with a coupon (manually enabled Automatic Discounts) only.
As with the standard setup, test all discounts before enabling the data extension to ensure they apply to the specified menu items.
See Discounts for configuration instructions.
