Using Simphony POS Operations and Mobile Solution Application on One Device
Your organization can run Mobile Solution 18.1 (used with Oracle Restaurants Inventory Management and Materials Control) on a Simphony tablet device. To share applications on the tablet device, you need to configure a button (using the Page Design module in the EMC) that closes the Simphony POS Operations application on the tablet device. (Minimizing Simphony does not release the scanner.)
                        When the device is powered on, Simphony POS Operations starts automatically.
                        The workstation operator must click the Close Application button to stop Simphony POS Operations.
                        The workstation operator must manually start the Mobile Solution application.
                        After using Mobile Solution, the workstation operator must stop it.
                        The workstation operator must manually start Simphony POS Operations.
Related Topics
Parent topic: POS Workstations
