Allowing Employees to Install and Authenticate Workstations and Service Hosts
You must allow administrator employees to download software, install, and authenticate workstations and service hosts using the appropriate CAL version. After granting this privilege, employees can use their credentials to configure workstations. In addition, the User Security Credentials configured in the Property Parameters module become inactive.
- Select the Enterprise, click Configuration, and then click Roles.
- Double-click an employee role.
- Click the Operations tab, click the Miscellaneous subtab, and then select 10065 - Download Software, Install and Authenticate Clients and Service Hosts Using CAL.
- Click Save.
