Page Design
Use Page Design to author and maintain the touchscreen pages displayed by workstations. A page defines the layout of buttons, functions, Screen Lookups (SLUs), numeric-entry areas, dining tables, and other controls that operators use to perform transactions and workstation operations.
When you create a page, select a page template that provides its layout and available page areas. You can then add and arrange controls, configure their behavior, and apply display styling. Page templates and their attributes are described in Page Templates.
Use Page Assignment to specify when workstations display each page. You can assign pages by hierarchy level and use conditions, such as employee class, serving period, or order type, to display a different page when the condition is met.
