Page Templates
Page templates define the layout and available areas of a workstation touchscreen page. Select a template when creating a page in Page Design. The template determines the page areas that can contain buttons, tabs, check detail, status information, and other controls.
Table 9-1 Page template categories
| Template Category | Description |
Classic |
Provides a layout similar to Simphony First Edition touchscreen templates. |
Blank |
Provides a starting layout for customized pages or a sign-in page. |
Tabbed |
Provides navigation tabs and subtabs. Use this category for sign-in and transaction pages that require multiple groups of controls. |
Handheld full-width check detail |
Provides a handheld layout with an expanded check detail area and configurable button areas. See Mobile Handheld Page Templates with Full Width Check Detail Area. |
Custom |
Uses a page template imported through the Page Templates module. See Configuring a Custom Page Template. |
Template attributes
For templates that support the HTML5 user interface, Page Design supports the same template configuration on Windows, Linux, and Android workstations. Configure the template once and use it across supported platforms.
Available attributes vary by template. Supported attributes include:
Tab item width and height
Top and bottom status bar height
Last Entry Area font size, which affects its height
Navigation bar font size and text alignment
Button-grid rows, columns, and page-area dimensions
Check detail and content-area dimensions for templates that include those areas
