Devices
Use the Devices tab to associate peripheral devices with a workstation.
Table 8-9 Devices tab fields
| Field | Description |
Peripheral Device Configuration |
Lists the peripheral devices associated with the workstation. |
Add Device |
Add a peripheral-device connection to the workstation. |
Edit Device |
Update settings for an existing peripheral-device connection. |
Peripheral Device Type |
Select the type of peripheral device to configure, such as a Simphony Payment Interface. Available settings depend on the selected type. |
