Revenue Centers
Use the Revenue Centers tab to control the revenue centers available when an operator signs in to the workstation.
Table 8-8 Revenue Centers tab fields
| Field | Description |
Revenue Centers |
Select the revenue centers available when an operator signs in to the workstation. |
Default Revenue Center |
Select the revenue center used by default. A default revenue center is required for a POS client to start. |
Default Transaction Touchscreen |
Select the transaction touchscreen shown after an operator signs in. This is not the sign-in screen. |
