General
Use the General tab to identify the workstation and configure settings that apply to the endpoint itself.
For wireless tablet devices, the Wireless Signal Strength Control values are inherited from Property Parameters unless they are overridden for the workstation. The configured threshold values appear in the workstation status bar.
Table 8-2 General tab fields
| Field or action | Description |
Workstation ID |
Shows the identifier assigned to the workstation. |
Type |
Select the endpoint type: Mobile, Workstation Client, POSAPI Client, Tablet Client, or Oracle Payments Order and Pay. |
Language |
Select the default language shown on the workstation sign-in screen. |
Workstation Class |
Assign a workstation class to group similar workstations for shared page configuration. |
Extension Application Log Verbosity |
Select the logging level used by supported extension applications. |
Enable Simphony Transaction Services (Gen1) Location API |
Enables the Gen1 Location API for a workstation running Simphony 19.9 or earlier. This API is not supported in Simphony 19.10 or later. |
Enable Simphony Transaction Services (Gen2) Location API |
Enables the workstation to host the Gen2 Simphony Transaction Services API. |
Enable Simphony Transaction Services (Gen2) Cloud API |
Enables the workstation to receive cloud orders. A valid OpenID Connector Provider URL is required. |
Service Host ID |
Shows the Service Host where the workstation application runs. |
Address / Host Name |
Enter the IP address or host name of the Service Host where the workstation application runs. |
Subnet Mask |
Enter the subnet mask used by the Service Host. |
Default Gateway |
Enter the default gateway used by the Service Host. |
Is Windows Service |
Runs the Service Host as a Windows service without a graphical user interface. |
Remove OPS From Service Host |
Removes the POS Operations client from the Service Host. The workstation record is deleted, and the Service Host record becomes available in the Service Hosts module. |
Database Update Frequency |
Set how often, in seconds, the workstation retrieves database updates. This value overrides the Property Parameters setting. |
Check Inactivity Timeout |
Set when the workstation prompts an operator about an inactive transaction. Enter 0 to prevent the prompt from appearing. |
Check Inactivity Dialog Timeout |
Set how long the inactivity dialog remains before the transaction is automatically canceled. Enter 0 to prevent automatic cancellation. |
Report Timeout |
Set how long, in seconds, the workstation waits for reporting information before treating the request as failed. |
Offline Threshold |
Enter a value from 0 through 99 for the wireless signal-strength percentage at or below which the device goes offline. |
Reconnect Threshold |
Enter a value from 0 through 99 for the wireless signal-strength percentage at or above which the device returns online after it is offline. |
Resolution Cols |
Set the number of display columns. The value must match a resolution defined in the workstation INI file; use 0 for the default. |
Resolution Rows |
Set the number of display rows. The value must match a resolution defined in the workstation INI file; use 0 for the default. |
Location From Top |
Set the workstation window position from the top of the display in pixels. |
Location From Left |
Set the workstation window position from the left of the display in pixels. |
