Overview
Each workstation record includes tabs that define the endpoint and the configuration used by its POS client, mobile device, or Transaction Services API.
Table 8-1 Workstation tabs
Tab Description
General
Identifies the workstation and sets its type, language, display, update, timeout, and network settings.
Service Host
Associates the workstation with the Service Host that runs its services.
Transactions
Sets transaction defaults, check-number ranges, barcode handling, cashier linkage, and merchant routing.
Options
Sets workstation behavior for display, sign-in, cash drawers, offline operation, peripherals, and other client features.
Order Devices
Associates the workstation with order devices and their output.
Routing Groups
Associates routing groups with output devices for the workstation.
Printers
Assigns printers or printer groups for workstation print jobs.
Revenue Centers
Sets the revenue centers and default touchscreen available to the workstation.
Devices
Associates peripheral devices and their connection settings with the workstation.
Service Log
Provides service-log information for the workstation.
Data Extensions
Provides extension-defined fields when an installed extension uses workstation data.
