Options
Use the Options tab to control behavior specific to a workstation.
Available options depend on the workstation type and installed hardware.
Table 8-4 Workstation options
Option Description
1 - Enable Keyboard/Screen Beeper
Plays a tone when an operator presses a key.
2 - Enable Error Beeper
Plays a tone when an error occurs.
3 - Require Cash Drawer to be Closed Before New Transaction
Requires attached cash drawers to be closed before a new transaction begins.
4 - Assign Cash Drawer By User Workstation
Requires operators to assign themselves to a cash drawer using an Assign Cash Drawer function key.
5 - Do Not Clear Screen After Transaction
Keeps the final transaction screen visible after completion.
6 - Enable Rear Line Display
Enables output to a rear customer line display.
7 - Use Other Cash Drawer for Other Currency
Uses one of two cash drawers for foreign currency. This option is unavailable when Enterprise Cash Management is enabled.
8 - On = Link Cashier Totals to WS; Off = Link to Operator
Links the workstation to one cashier record for cashier totals.
12 - Mag Card Entry Required for Employee ID
Requires all employee ID entries, including sign-in and privileged-operation authorization, to use a magnetic employee ID card. The workstation does not accept employee IDs entered by keyboard or touchscreen.
17 - Allow Offline Operations
Allows the workstation to operate in Offline Mode.
21 - Disable Employee Auto Sign Out
Prevents the Automatic Operator Popup Interval from signing out operators at this workstation.
27 - Disable Auto-Online
Prompts operators before returning to online operation after communications are restored.
28 - Is Kiosk
Identifies the workstation as a kiosk.
29 - Go Offline Without Prompting
Allows the workstation to enter Offline Mode automatically when communication is lost.
33 - Show Cursor
Shows the mouse cursor on PC-based workstations.
36 - Use Alternate ID for Sign-in
Allows operators to sign in with the four-digit Alternate ID from their employee record instead of the ten-digit employee ID.
39 - Floating Tablet
Identifies an Oracle tablet that is not docked to a base station.
41 - Require Cash Drawer Assignment to Begin Transaction
Requires an operator to have a cash drawer assigned before beginning a transaction.
42 - Display Discounts on Customer Display
Shows discount totals and the amount due on the customer display.
43 - Auto-Pickup Next Check
In a drive-through payment window, automatically picks up the oldest eligible open check after payment.
44 - Use LCD Customer Line Display
Uses an LCD customer line display instead of a pole display.
45 - Exclude this Workstation from EMC Module Version Validations
Excludes a configured but nonphysical workstation from EMC version validation.
46 - Disable Auto Combo Items on the Fly
Overrides the revenue center Auto Combo Items on the Fly setting for this workstation.
47 - Fingerprint Scan Required for Employee ID
Requires a fingerprint scan for all employee ID entries, including sign-in and privileged-operation authorization. The workstation does not accept employee IDs entered by keyboard or touchscreen.
48 - Employee ID or Fingerprint Scan Required for Employee ID
Requires employee ID entry by fingerprint scan or by keyboard or touchscreen.
49 - Employee ID and Fingerprint Scan Required for Employee ID
Requires both a fingerprint scan and employee ID entry by keyboard or touchscreen.
50 - Mag Card or Fingerprint Scan Required for Employee ID
Requires either a magnetic card swipe or fingerprint scan for employee ID entry.
51 - Mag Card and Fingerprint Scan Required for Employee ID
Requires both a magnetic card swipe and fingerprint scan for employee ID entry.
52 - Do not display currency symbol on rear/customer display
Hides the currency symbol on the rear or customer display.
53 - Display non-rounded amounts on rear/customer display
Shows the non-rounded amount due on the customer display. The Currency Parameters Round Currency option must also be selected.
54 - Display Change to dispense in Bills in the Change due dialog
Shows the amount to dispense in bills in the Change Due dialog.
55 - Enable Encrypted Magnetic Stripe Reader Support
Enables an encrypted magnetic stripe reader. This option cannot be cleared after it is selected.
57 - Only use DynaPro as credit card reader
Allows credit card swipes only through a DynaPro reader.
59 - Concessions terminal
Identifies the workstation as a concessions terminal for license counting.
60 - Launch KDS Display
Starts the KDS Display application when POS Operations starts.
61 - Always Hide Frame
Hides the POS Operations window frame when the user interface is not full-screen.
62 - Prompt for Destination Printer when docked
Prompts for a configured destination printer when the workstation is docked.
63 - Enable Cashback
Enables cashback when cashback is also enabled for the employee class.
67 - Enable Customer Facing Display
Enables output to an attached customer-facing display.
68 - Third Party Managed Device
Enables a third-party payment service provider (PSP) and its mobile device management (MDM) platform to distribute Simphony software to Android devices. This option is available only for Mobile, Workstation Client, and Tablet Client workstation records. When enabled, the client verifies that its CAPS version matches the Service Host version and prompts for an upgrade or downgrade of the Simphony application when the versions do not match.
69 - Exclude from Telemetry
Excludes the workstation from Telemetry Hub location and device-status metrics.
