Transactions
Use the Transactions tab to set defaults and identifiers used while the workstation processes transactions.
Table 8-3 Transactions tab fields
| Field | Description |
Minimum Check Number |
Set the first guest check number used while the workstation is offline or when the revenue center does not use revenue center check numbers. In these revenue centers, the workstation determines its own check-number range. |
Maximum Check Number |
Set the last guest check number used while the workstation is offline or when the revenue center does not use revenue center check numbers. In these revenue centers, the workstation determines its own check-number range. |
Default Order Type |
Select the order type that remains active until an operator changes it, such as Dine In, Take Out, or Drive Thru. |
Default Order Channel |
Select the default order channel for the workstation. |
Barcode Format Set |
Select the barcode format set used by the workstation to read barcodes of different lengths. |
Cashier Link |
Select the cashier totals linked to the workstation. This field is used only when the workstation is first created. After the workstation is saved and CAL is run, manage the cashier assignment with the Assign Cashier function. This field is available only when workstation option 8 links cashier totals to the workstation. |
Merchant Group |
Select the merchant group used by the workstation, or select 0 to use the revenue center setting. Merchant groups can route payment information to different banks when a workstation serves multiple revenue centers. |
Thai Tax RD Number |
Enter the number printed on Thai Tax trailers, where applicable. |
Macro Loop Count |
Set the maximum number of times a macro can loop before it stops. This setting is generally used for testing and requires the workstation macro-loop option. |
Cash Drawers |
Select the number of cash drawers physically installed at the workstation. |
Cash Drawer Beep Timeout |
Set the number of seconds a cash drawer can remain open before the workstation starts beeping. Enter 0 to disable the beep. This setting requires workstation option 3, Require Cash Drawer to be Closed Before New Transaction. |
Cash Drawer Notify Timeout |
Set the number of seconds a cash drawer can remain open before the workstation writes a message to the journal log. Enter 0 to disable the message. This setting requires workstation option 3, Require Cash Drawer to be Closed Before New Transaction. |
