OPERA PMS Interface Settings
Posting Related Settings
The following tables list the string names and values to be used in the Content module for the OPERA content text file.
Table 43-1 Posting Related Settings
Configuration String Configuration Value
MAGCARDONLY
Set to 0 to allow both magnetic cards and keyboard inputs.
Set to 1 to limit the entries in the Room Charge event to magnetic cards.
MAGCARDOVRWRT
When MAGCARDONLY is enabled, you can overwrite the setting for certain revenue centers by entering a list of revenue center numbers (separated by comma).
SUPPRESSGSTMSG
Set to 1 to suppress the message indicator during posting. Enable this setting for high-volume sites.
SUPPRESSNFOREF
Non-Room Charge tenders show the Department Code for which they were posted. Set to 1 to suppress this reference.
REVERSEGST
Set to 1 to make the guest count negative when the payment is negative (that is, the payment is voided). This feature requires specific configuration on the Front-Office interface to work correctly.
FULL_DSVC
Set to 1 to send the full breakdown of the discounts. This requires a specific version of the Front-Office interface.
Set to 2 for an additional full breakdown of the service charges. This includes the full breakdown of discounts.
NO_CONFIRM_GST
Set to 0 if magnetic cards are used to identify guests.
Set to 1 to prevent confirmation of the guest name when posting.
POST_64TAXES
Set to 1 to send up to 63 Tax Itemizers to the Front-Office interface. This feature requires IFC8 V.8.7.1.2 or later as well as a certain version of the Front-Office itself.
Set to 0 to send only 8 Tax Itemizers to the Front-Office interface.
SendAllDtls
Set to 0 to send only the check details of Room Charges the Front-Office interface.
Set to 1 to send also the check details of non-Room Charges.
RESTRICTED_POSTING
Select to restrict the response returned from the Front-Office Interface in the Room Charge event. Note that this only works in combination with the option RESTR_POSTING_EMPL is configured correctly. There are two values supported:
  • Set to 1 to require both the room number and at least three characters of the surname (last name) to post the room charge. If less than three characters are provided an error appears. If the response from the PMS contains more than one record, an error appears and the workstation operator must enter additional characters to provide a unique identifier.
  • Set to 3 to assume that an external device will provide the input as keyboard data. There is no touchscreen keyboard shown when this option is used. The workstation operator (or guest) has only the option to abort the input. If the response from the PMS contains more than one record an error appears and the posting is aborted. There is no confirmation of the guest-name shown, irrelevant of the setting in NO_CONFIRM_GST.
Note that this feature does not work if the input is restricted to magnetic cards. Therefore, you must either disable the restriction or add the relevant revenue center to the excluded list of revenue centers.
RESTR_POSTING_EMPL
Specify the ISL Option to use with the above option (see ISL Options in the Employee Maintenance module). The valid value for this configuration is between 1 and 8.
Locator and Message Settings
Table 43-2 Guest-Locator and Guest-Message Settings
RVCNAMELOC
Set to 1 to have the first line of the locator contain the revenue center name, otherwise the locator name is blank. Workstations operator can overwrite this value when entering the locator information.
LOCVALIDMIN
Each new locator is only valid for a certain time. Enter the default time in minutes for which the locator is valid. Workstation operators can overwrite this value when entering the locator information.
