Hiding Condiment Groups on a Condiment Orderer Page
You might not list a condiment group on the Condiment Orderer page if condiments are not present in the group of the current order. In this case, you can specify one or more condiment groups to hide from view.
The Condiment Orderer hides selected condiment groups—required or allowed. Hiding required condiment groups could lead to ordering issues on the POS workstation.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Insert a new page record or select an existing page, and then select Condiment/Combo Orderer.
  3. Click the Select Condiment Groups link, select the condiment groups to hide, and then click Set.
    Figure 17-20 Select Condiment Groups to Hide
    This figure shows the Page Design module Condiment/Combo Orderer section where you can select condiment groups to hide from view.
  4. Click Save.
    After condiment groups are hidden, their object numbers appear within the Condiment groups to hide: field (separated by commas).
