Creating Menu Item Classes for Condiments
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes
  2. Insert a new record, enter the class name, and double-click the new record.
  3. On the General tab, select the Condiment Order Type from the drop-down list. The Condiment Order Type describes how the condiment is added to a check when it is ordered.
    Table 17-17 Condiment Order Types
    Condiment Order Type Description
    0 - Add
    Select to add a new item to the check.
    1 - Increment
    Select to add the item if it does not exist for the parent, or to increment an existing item.
    2 - Replace In Condiment Group
    Select to remove items that exist in the item’s member condiment group before adding it (this simulates a radio button effect).
    3 - Replace In Master Group
    Select to remove items that exist in the item’s master group before adding it.
    4 - Toggle
    Select to switch the item on and off.
  4. Click the Options tab, and then select 2 - ON = Condiment Menu Items; OFF = Regular Menu Items.
    When you select this option, Simphony updates the Type column in table view to Condiment for this menu item class. For a menu item to be a condiment, it must belong to a class where at least one Member Condiment Group is enabled.
  5. To set no charge for the condiments in this class, select 8 - Allow Menu Items in this Class to be Non-Priced.
    To prevent a condiment from printing on the guest check if it does not have an associated price, see Configuring Menu Item Classes, specifically option 79 - Do not print unpriced condiments on Guest Checks.
  6. To set each condiment in this class to print to a specific order device, select 22 - ON = Use Own Output Link; OFF = Use Parent's (Condiments Only).
    By default, the ideal setup of a condiment group class is to keep this option deselected and to select all order devices as the output. This ensures that the condiment always follows the parent item to its order devices. This option does not apply to Condiment Prefixes.
  7. To override order device settings of the parent menu item, select 58 - Condiment order device programming overrides that of parent.
    When this option is selected, order devices configured for the condiments class override the order devices defined for parent menu items. Use this option in a situation where a menu item is sent to a different order device when a specific condiment is added. For example, a muffin served at room temperature outputs to the Pantry order device. Warm is set to output to the Hot order device. When the Condiment Warm with this option set is added to the menu item muffin, the muffin will use the order device output of the Warm Condiment and go to the Hot order device instead of the usual Pantry. This option does not function if the menu item is a Condiment Prefix.
  8. Click the Condiment Groups tab, and then select the Member Condiment Groups for the class.
    For example, if the condiment class is Deli Meat Class, select Meat Group from the Member Condiment Groups list.
  9. Click Save.
  10. Repeat Steps 2 through 9 to create menu item classes for all condiment groups.
