Adding a Customer Facing Display (CFD)
You can attach a touch-enabled CFD to a workstation to let guests review their orders for accuracy as workstation operators enter the orders. You can attach a CFD to an Oracle Workstation 8, Oracle Workstation 625, or Oracle Workstation 655. The CFD shows translated text as defined in the language settings for the enterprise.
Before starting this procedure, verify the workstation has been installed at the property, the CFD has been attached to it, and a workstation record has been added to the EMC for the property.
Parent topic: Customer-Facing Displays
