Configure Uber Eats Menu Language
The Uber Eats menu API supports only one language per menu. If the required language for the Uber Eats menu is different from the Simphony default language, you must specify the menu language for a location in a property-level data extension.
- Select the Enterprise, click Configuration, and then click Data Extensions.
- Insert a new record.
- Configure the fields for the new data extension.
Table 14-18 UberEatsMenuLocale Fields
Field Details Table
Select 1001 - Property
Extra Column Name
Enter
UberEatsMenuLocale.Type
Select 0 - Text.
Data Constraints
Max Chars: 128
Sort Priority
Not applicable; use the default value
Display Width
Enter
150Translatable Name
Translatable Help
- Click Save.
- Select the Enterprise, click Setup, and then click Properties.
- Select the property that requires a different language for the Uber Eats menu.
- Click the Data Extensions tab.
- Locate the
UberEatsMenuLocaledata extension, and enter the language code as it appears in the Language Culture field (set in the Languages module).See Configure Language Culture for more information.
- Click Save.
