Setting Privileges to Access Effectivity Groups
To enable the view and edit privileges for effectivity groups:
  1. Select the Enterprise, click Configuration, and then click Roles.
  2. Insert a record for a new employee role or double-click an existing role to open it.
  3. Click the Fields tab, and then highlight the Effectivity Groups row under the EMC Modules section.
  4. In the Fields section, click the drop-down list under the Access column, and then select 0 - Editable.
    See Creating Roles for more information.
  5. Click Save.
