Creating Roles
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Insert a record for the type of role (for example, host, bartender, server, manager, or administrator), and then click OK.
  3. Double-click the role type.
  4. On the General tab, select the role security from the Level drop-down list.
  5. Click the EMC Modules tab.
  6. For each EMC module listed in the File column, select one or more appropriate permissions.
  7. Click the Actions tab.
  8. Select Enable for the appropriate EMC tasks listed in the Action column.
    To activate a role for every module without individually selecting each option, right-click the Enable heading, and then select Set All.
  9. Click Save.
