Employee Classes
You can set collective options for a group of similar employee roles using an Employee Class. Each employee must belong to an Employee Class to perform workstation operations.
  1. Select a property, click Configuration, and then click Employee Classes.
  2. Insert a record.
  3. Double-click the record to open it.
  4. On the General tab, set information for the fields as described in the following table.
    Table 5-18 Employee Class Settings
    Field Description
    ISL Options
    Select the ISL Employee Options to allow employees in the Employee Class to execute Interface Script Language (ISL) scripts.
    Cash Management Accounting Method
    Defines the type of Cash Management session employees in this class use to record Cash Management transactions. Select Till Banking, Server Banking, or None.
    Server Banking Template
    Defines the default template used when a new Server Bank opens. This setting overrides the template in Cash Management Parameters. It is active only when Server Banking is selected for the Cash Management Accounting Method and lists the available Server Bank templates.
  5. Click the Operator Options tab.
  6. For each revenue center listed, from the Operator Type drop-down list, select the guest check printing method.
    Table 5-19 Operator Check Printing Options
    Option Description
    By Round
    Select this option to print a guest check at the end of each service round, showing only the changes posted to the service round.
    On Demand
    Select this option to print a buffered guest check after performing a Service Total or tender set to print an on demand check.
    Temp On Demand
    Select this option to print a guest check on demand (in a by round manner).
    Special By Round
    Select this option to print a guest check on demand for all rounds except the first round of a check. The first round always prints. Subsequent service rounds print if the Service Total is set to print an on demand check.
  7. For each revenue center listed, select the appropriate Options, and then click OK.
    Table 5-20 Operator Options
    Option Description
    1 - Table Number Entry Required to Begin/Pickup Checks
    Requires table number entry when beginning a check.
    2 - Number of Guests Entry Required for New Checks
    Requires number-of-guests entry when beginning a check. You can override this setting by selecting Use Number of Seats for Guest Count in RVC Parameters.
    3 - Require Check Employee Number with New Checks
    Requires assignment of a check employee when beginning a check. Operators enter an Employee ID when Option 4 is deselected or an Employee Number when Option 4 is selected. This setting affects sales totals and tender posting configured in RVC Parameters.
    4 - Use Employee Number to Open Check for Another Employee
    Requires the Employee Number of the operator for whom the check is being started. When deselected, requires the other operator's Employee ID. You must also configure Require Check Employee Number with New Checks, Auto Begin Check when Check Operator Number or ID is Entered Outside of a Transaction, or Open Check Block Settlement.
    7 - Cannot Perform Fast Transactions
    Requires opening a check to begin each transaction. When deselected, operators can begin a check by adding a menu item.
    8 - On = Popup Operator; Off = Stay Down Operator
    Signs the operator out of the workstation at the end of a transaction. When deselected, the operator remains signed in after each transaction.
    14 - Require Seat Number Entry
    Requires the operator to have an active seat number when beginning a transaction.
    15 - If Staydown Operator, Enable the Auto Popup Timeout
    Automatically signs out a staydown operator according to the Automatic Operator Popup Interval in Control Parameters. When deselected, staydown operators remain signed in.
    16 - Require Guest Check ID
    Requires checks opened or picked up by the operator to have a Guest Check ID, which lets an operator add custom information to a check.
    23 - Sort the Guest Check SLU by Table Name
    Sorts the Open Checks SLU for the operator by Table Name. Autofire checks appear at the bottom, sorted by AutoFire time and then Table Name.
    25 - View Blind Totals
    Allows operators to view over and under calculations on count sheets.
    26 - Allow Assigned Receptacle Access
    Allows operators to view and perform transactions for till and server bank receptacles when they are not the owner or assigned user.
    27 - Prevent Multiple Receptacle Counts
    Prevents operators from counting a till or server bank receptacle more than once.
    28 - Prevent Transactions Once a Count Has Been Performed
    Prevents an operator from performing transactions after a count when Option 27 is enabled. Does not prevent Count Adjustment, Bank Deposits, or Transfers Out.
    29 - Treat Menu Item Price Overrides as Unit Price
    When a menu item quantity and an overridden price are specified, treats the overridden price as a per-unit price and multiplies it by the quantity. Applies to STS Gen1 only.
    30 - Allow Deposit Without Count
    Allows users to deposit from a receptacle without first counting it.
  8. Click Save.
