Configuring Financial Shift Tracking
Financial shift tracking separates employee, employee tip, and cashier financial totals into reporting periods. A financial shift is an accounting bucket; it does not define an employee's scheduled working time or calculate labor.
Use financial shift tracking when an employee has more than one accountable period in a business day, such as when the employee works two shifts, or when an employee works overnight through Start of Day. In these cases, business-date financial reports can span more than one accountable period. Financial shift reports isolate the employee's accountable sales for each financial shift, eliminating the need to combine results from multiple business-date reports.
Configure when employee and cashier financial shifts increment and whether users are prompted before an increment.
  1. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Control Parameters.
  2. Click the Options tab, and then select the appropriate financial shift tracking options.
    Table 5-21 Financial Shift Tracking Options
    Option Description
    49 - Enable Shift Tracking
    Select this option to activate shift reporting, segregating employee, employee tip, and cashier financial totals by shift.
    50 - Increment Cashier Shift when Clocking Out
    Select this option to increment the shift for the cashier associated with the employee clocking out (except when clocking out on break).
    51 - Increment Cashier Shift when Clocking In
    Select this option to increment the shift for the cashier associated with the employee clocking in (except when returning from break).
    52 - Increment Cashier Shift when Changing Job
    Select this option to increment the shift for the cashier associated with the employee when they clock in with a different job. This clock in occurs automatically when the employee signs on to a workstation with a different revenue center than the job in which they are currently clocked in.
    53 - Increment Cashier Shift when Changing Revenue Center
    Select this option to increment the shift for the cashier associated with the employee when signing on to a different revenue center.
    54 - Prompt before incrementing Cashier Shift
    Select this option to prompt the employee to increment the shift for the cashier associated with the employee when the shift is set to increment upon clocking in or out, changing jobs, or changing revenue centers.
    55 - Prompt to Increment Cashier Shift after Shift Report
    Select this option to prompt the workstation operator to increment the cashier shift when a Cashier Shift Report is generated with a shift scope.
    56 - Increment Employee Shift when Clocking Out
    Select this option to increment the shift for the employee upon clocking out (except on break).
    57 – Increment Employee Shift when Clocking In
    Select this option to increment the shift for the employee upon clocking in (except when returning from break).
    58 - Increment Employee Shift when Changing Job
    Select this option to increment the shift for the employee when clocking in with a different job. This clock in occurs automatically when the employee signs on to a workstation with a different revenue center than the job in which they are currently clocked in.
    59 - Increment Employee Shift when Changing Revenue Center
    Select this option to increment the employee shift when signing in to a different revenue center.
    60 - Prompt to Increment Employee Shift after Shift Report
    Select this option to prompt the workstation operator to increment the employee shift when an Employee Shift Report is generated with a shift scope.
    61 - Prompt before incrementing Employee Shift
    Select this option to prompt the workstation operator to increment the employee shift when the shift is set to increment upon clocking in or out, changing jobs, or changing revenue centers.
  3. Click Save.
  4. Select the revenue center, click Setup, and then click RVC Parameters.
  5. Click the Calendar tab.
  6. From the Shift Incrementing Options section, select the following options to prevent Employee or Cashier Financial Shifts from resetting at the start of the business day:
    • Do not reset Employee Financial Shifts with the start of each business day
    • Do not reset Cashier Financial Shifts with the start of each business day
  7. Click Save.
