Deleting a Person
If you are using
  • Simphony 19.6 or later with Reporting and Analytics 20.1.15 or later
and your EMC employees are managed through People Management, use People Management in Simphony Home to delete an employee from the system. The Oracle Restaurants Reporting and Analytics User Guide, located on the Oracle Help Center, contains more information about People Management.
If you are using one of the following versions of software
  • Simphony 19.5 or earlier
  • Simphony 19.6 or later with Reporting and Analytics 20.1.14 or earlier
without managing your EMC employees through People Management, follow the steps in this topic to delete an employee through the Simphony EMC. You must have the Enterprise level permission called Delete Employees to remove an employee record.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Employee Maintenance.
  2. Search for the employee record.
  3. Right-click the employee record, and then select Delete.
  4. From the Delete Employee Records dialog, click Yes to confirm.
  5. To view a list of all deleted employees in the search area, select View Deleted Employees, and then click Search.
  6. To reactivate a deleted employee, right-click the employee record, select Reactivate, and then click Yes to confirm.
    After an employee has been de-identified, the employee cannot be reactivated because the employee’s personally identifiable information has been deleted from Simphony and cannot be reconstructed. Removing Personal Data from Simphony contains more information about de-identification.
  7. If you are an administrator and want to permanently delete an employee, right-click the employee record, select Permanently Delete, and then click Yes on the prompts to confirm.
    You cannot permanently delete an employee who is not marked Is Deleted and who has associated sales or timecard records in the Reporting and Analytics database. Employees are mapped between the Simphony and Reporting and Analytics databases using the object number from the EMC. Consider the following example:
    • Employee 12345, Ted Davis, has $500 in sales
    • Employee 12345 is deleted from the database
    • If the EMC allowed this employee to be permanently deleted, a new employee, Mary Smith, could be added at employee record 12345 and the new employee would essentially start with $500 in sales
    Thus, the two-step employee deletion process preserves the object number between the two databases. Because of this potential scenario, object numbers are not reusable. If employee 12345 shows as Is Deleted in the database, you cannot create a new employee record using number 12345.
  8. Click Save.
  9. To withdraw an employee’s consent, see Withdrawing Consent.
