Adding Images to Menu Items
- Sign on to the workstation, and then tap the Hub function.
- Tap the tile configured for the Copy Menu Item manager function.
- Select the menu item, and then tap Update Image.
- Tap Browse Image, select the menu item image, and then tap Open.
