Adding a New Menu Item Using an Existing Menu Item as a Template
- Sign on to the workstation, and then tap the Hub function.
- Tap the tile configured for the Copy Menu Item manager function.
- Select a menu item that belongs to the same menu item class and print class that you want to assign to the new menu item, and then tap Copy Menu.
- Configure the following details for the new menu item:
Table 41-3 Configuration Fields for Adding New Menu Items From a Template
Field or Option Name Description Menu Item Master Name
Enter the new menu item name.
Definition
Select the appropriate menu item definition.
If the menu item that you are using as the template has several definitions, all definitions appear in the list.
Menu Item Definition Name
Enter the name for the new menu item definition.
Price
Enter the menu item price.
- To change the image for the menu item:
- Tap Change Picture, and then tap Browse Image.
- Select the new image, and then tap Open.
- Click Add Menu, and then tap OK to confirm the insertion.
