Configuring Distribution Privileges
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type, click the Actions tab, and then select the appropriate privileges:
Table 2-6 Distribution Privileges
Privilege Name Allows the Employee to ... Distribute
Use the EMC Distribute function.
Remote Distribute Out
Move data from one revenue center to another revenue center or from one property to another property between two different Simphony systems. Select this option to allow employees associated with this role to remote distribute from this Simphony system out to another Simphony system.
Employees need login credentials with permissions on the receiving Simphony system to Remote Distribute In.
Move data from one revenue center to another revenue center or from one property to another property between two different Simphony systems. Select this option to allow employees associated with this role to remote distribute from another Simphony system into this Simphony system.
Employees need Remote Distribute Out permissions on the other system to distribute in.
- Click Save.
