Configuring Screen Language Buttons
If more than one language is configured, you can create touchscreen buttons to allow workstation operators to switch between the languages.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place the language buttons, and then on the Edit tab, select the page area in which to define the buttons.
  3. Click Button, and then on the General subtab, select Function from the Type drop-down list.
  4. Click the black arrow directly beneath the Type drop-down list, and then select Multi Language from the Type pane.
  5. To allow workstation operators to select the preferred language from a list, select Screen Language List, and then click OK.
  6. To configure separate touchscreen buttons for each language configured for the property, select Screen Language 1, and then click OK.
    Screen Language 1 shows the descriptors for the default language.
  7. Enter a Legend for the button, and then position and size the button on the page.
  8. If you are creating separate buttons for each language, repeat Steps 3 through 7 and configure buttons for the following:
    • Screen Language 2: Shows the descriptors for the second language defined in the system.
    • Screen Language 3: Shows the descriptors for the third language defined in the system.
    • Screen Language 4: Shows the descriptors for the fourth language defined in the system.
  9. Click Save.
