Setting Languages for the Property
You can specify up to four languages that are available to be used at the property. Workstation operators can then switch between the four different languages on the fly, independent from the employee language settings. For example, if an employee has a different language assigned than what is set for the property, the workstation operator will be prompted to select any of the available languages of the property upon first signing in to the workstation.
After configuring languages for a property, all workstations must receive the new database updates and must be restarted prior to the changes becoming active.
- Select the property, click Setup, and then click Property Parameters.
- On the General tab, select the default language from the Language 1 drop-down list.
- (Optional) In the Language 2 through Language 4 drop-down lists, select the secondary languages.
- Click Save.
Parent topic: Standard Languages
