Changing the Default Enterprise Language
You can change the organization’s default UI language from English to another language for workstations, and in the EMC for text labels, options, help text, and error messages. You need to manually change the language for EMC records, menu items, and touchscreen buttons.
  1. Select the Enterprise, click Setup, and then click Languages.
  2. Insert a record and enter a name (for example, Spanish).
  3. Double-click the record to open it.
  4. On the General tab, select the language from the Keyboard Type drop-down list.
  5. On the Printing tab, set the following options (if needed):
    • Print Custom Numerals: Select this option to print numerals defined in the Custom Numerals field on the General tab.
    • Asian Characters: Select this option for languages such as Chinese, Japanese, Thai, and Korean where characters are picture-based. When you select this option, characters print double-wide to make them more readable. The order device printer also prints double-wide characters to maximize readability.
    • Mapping Font: By default, this option is set to Amap (used for English and Arabic). Select Vmap for Thai, Hebrew, and all other languages.
  6. Click the Miscellaneous tab.
  7. Select the language from the Locale String drop-down list. The following table lists all languages currently supported in Simphony.
    Table 6-1 Supported Language Settings
    Language Locale String Local ID Language Culture
    Arabic
    Arabic-SaudiArabia
    Arabic (Saudi Arabia)
    ar-SA
    Chinese (Simplified)
    chinese-simplified
    Chinese (People's Republic of China)
    zh-CHS
    Chinese (Traditional)
    chinese-traditional
    Chinese (Taiwan)
    zh-CHT
    Danish
    danish
    Danish (Denmark)
    da-DK
    Dutch
    dutch
    Dutch (Netherlands)
    nl-NL
    English
    english-us
    English (United States)
    en-US
    Finnish
    finnish
    Finnish (Finland)
    fi-FI
    French
    french
    France (France)
    fr-FR
    German
    german
    German (Germany)
    de-DE
    Italian
    italian
    Italian (Italy)
    it-IT
    Japanese
    japanese
    Japanese (Japan)
    ja-JP
    Korean
    korean
    Korean (Korea)
    ko-KR
    Norwegian
    norwegian
    Norwegian (Norway)
    nb-NO
    Portuguese (Brazil)
    portuguese
    Portuguese (Brazil)
    pt-BR
    Portuguese (Portugal)
    portuguese
    pt-PT
    Russian
    russian
    Russian (Russia)
    ru-RU
    Spanish
    spanish
    Spanish (Spain)
    es-ES
    Swedish
    swedish
    Swedish (Sweden)
    sv-SE
    Thai
    chinese
    Thai (Thailand)
    th-TH
    Turkish
    turkish
    Turkish (Turkey)
    tr-TR
    See https://docs.oracle.com/cd/E13214_01/wli/docs92/xref/xqisocodes.html for a more detailed list of language codes (not all of the languages listed on this website are supported by Simphony).
  8. Select the Local ID from the drop-down list, and then enter the Language Culture corresponding to the language.
  9. Click Save.
