Creating Loyalty and Stored Value Buttons
You can create buttons for use on a POS Operations page for the loyalty and stored value functions.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
- Open the page on which to place loyalty and stored value buttons.
- On the Edit tab, select the page area in which to define the loyalty and stored value functions (typically the payment or function area).
- Click Button.
- On the General subtab, select the
appropriate function from the Type drop-down
list.
Loyalty Function
Stored Value Function
- Click the black arrow beneath the Type drop-down list.
- Select one of the following, and then click OK.
iCare Loyalty: Select for Oracle Restaurants Gift and Loyalty.
iCare Stored Value: Select for Oracle Restaurants Gift and Loyalty.
Loyalty: Select for Valutec loyalty.
Stored Value: Select for Valutec gift cards.
- From the Loyalty or Stored Value Operation Selection dialog,
select the appropriate Module Type and Functions, and then click OK.
iCareLoyaltyModule: Select for Oracle Restaurants Gift and Loyalty.
iCareSVCModule: Select for Oracle Restaurants Gift and Loyalty.
VTLoyaltyModule: Select for Valutec loyalty.
VTStoredValueModule: Select for Valutec gift cards.
- Position and size the button on the page. Use the Style arrow to change the color.
- In the Legend field, enter the button
name, and then click Save. The following tables
list the loyalty and stored value button names and functions.
Buttons marked with an asterisk (*) are only available with Gift and Loyalty; these functions are not available with third-party payment providers.
Table 36-12 Loyalty Buttons
Button Name Function Balance Inquiry
Request a points balance for a loyalty account.
Unique Items Inquiry*
Request a list of unique menu items that have been ordered on a program associated with a loyalty account.
Issue Points
Issue points to a loyalty account.
Coupon Inquiry
Request a list of coupons that are available for a loyalty account.
Redeem Coupon
Redeem a coupon to apply towards the balance of a guest check.
Issue Coupon
Issue an ad hoc coupon from Gift and Loyalty to a guest loyalty account.
Transfer Loyalty Account
Transfer the points balance and customer personal information associated with one loyalty account number to another loyalty account.
Apply Card to Check*
The Apply Card to Check function sends an Apply request to Gift and Loyalty for the account number. Based on Gift and Loyalty configuration, the workstation operator can select the following actions:-
Apply Coupon
Redeem Points
Redeem Stored Value Card (SVC)
Apply Coupon and Redeem SVC
Issue Points
The Apply Card to Check function requires a special configuration to share data between the Loyalty and Stored Value modules. To configure the Apply Card to Check button on the General tab, in the Text field, enter the SVCModule Name and Record Number. Use the format SVCModuleName:RecordNumber to process SVC actions associated with this function. You can find the Record Number and Module Name in EMC by highlighting the Enterprise, selecting Setup, and then clicking Stored Value Module.
A property can load more than one type of loyalty module, although it is not recommended. If the property uses multiple loyalty modules, manually enter the module name in the Arguments field for the second module.
Table 36-13 Stored Value Buttons
Request the current monetary value for a stored value account or gift card.
Issue SVC
Issue one stored value account number for a dollar value that is determined at the time of purchase.
Issue Multiple SVCs*
Issue multiple stored value account numbers for a dollar value that is determined at the time of purchase.
Activate SVC
Activate one stored value account. The application prompts the workstation operator to enter the pre-defined dollar value for validation.
Activate Multiple SVCs*
Activate multiple stored value account numbers for a dollar value that is determined at the time of purchase. The application prompts the workstation operator to enter the pre-defined dollar value for validation.
Reload
Add funds to an existing stored value account.
Transfer
Transfer the funds and customer personal information (if applicable) associated with one stored value account to another stored value account.
Authorize
Authorize a gift card for use as payment on a guest check.
Redeem
Pay a guest check balance using a gift card.
Cash Out
Obtain a cash payment for any remaining balance on a stored value account.
Redeem SVC/Issue Points*
The Redeem SVC/Issue Points function combines the Redeem SVC and Loyalty Issue Points functions. The application prompts the workstation operator to redeem a gift card, and then automatically issues points.
The Redeem SVC/Issue Points function requires a special configuration to share data between the Loyalty and Stored Value modules. To configure the Redeem SVC/Issue Points button on the General tab, in the Text field, enter the LoyaltyModule Name and Record Number. Use the format LoyaltyModuleName:RecordNumber to process loyalty actions associated with this function. You can find the Record Number and Module Name in EMC by highlighting the Enterprise level, clicking Setup, and then clicking Loyalty Module.
For SVC transactions, you can suppress a prompt for entry of the Total Amount Due by enabling Tender/Media option 3 - Assume Paid in Full, and by setting the Text field of the Redeem button in the Page Design module to: RedeemAmountIsTotalDue.
A property can load more than one type of stored value module, although it is not recommended. If the property uses multiple stored value modules, manually enter the module name in the Arguments field for the second module.
- Repeat the preceding steps to create buttons for each of the loyalty and stored value functions listed in the tables.
