Configuring the Stored Value Module
- Select the Enterprise, property, or revenue center, click Setup, and then click Stored Value Module.
- Insert a record, enter SVCModule as the name, and then click OK.
If you are using Valutec, you can name the module record VTStoredValueModule.
- Double-click the record to open it.
- On the General tab, click the Import from a file link.
- Browse to [Drive Letter]:\MICROS\Simphony2\EgatewayService\handlers,
select StoredValueCommandModule.dll, and then
click Open.
If you are using Valuetec, select VTStoredValueCommandModule.dll, and then click Open.
- Click the Configuration tab.
- In the Assembly/Class section, enter information in the
following fields:
Module ID: Enter the module identification. For Valutec, enter
VTStoredValueModule. -
Display Name: Enter a name for the module (for example,
Stored ValueorVTStoredValue). -
Description: Enter a description of the stored value module. Do not leave this field blank.
- In the Common Properties section, enter information in
the following fields:
Currency ISO Code: Enter the code (three alpha characters) that represents the currency being used (for example, USD).
See www.currency-iso.org/en/home/tables/table-a1.html for a list of Currency ISO 4217 codes.
Language ISO Code: Enter the code (two alpha characters) that represents the language being used (for example, EN).
See www.loc.gov/standards/iso639-2/php/code_list.php for a list of Language ISO 639–1 codes.
If the currency or language is different at the property, override these values at the property level.
- In the Stored Value Module Properties section, enter information
in the following fields:
Account Number Maximum Length: Enter the maximum length of a stored value account number (up to 24 digits).
Account Number Minimum Length: Enter the minimum length of a stored value account number (down to 7 digits).
Cash Module Name: Enter the name of the cash module to use for redemptions (for example, Cash:Cash).
Max Card Activation Quantity: Enter the maximum number of stored value cards that can be activated with the Activate Multiple card operation.
Max Card Issue Quantity
: Enter the maximum number of stored value cards that can be issued with the Activate Multiple card operation.
- Click Save.
- Select the property, click Setup, and then click Stored Value Driver.
- Double-click the stored value card driver record to open it.
- Click the Override This Record link, and then click Yes to confirm.
- From the iCare Driver Properties section, enter information
Login: Enter the login for the property ID or the login for the provider.
Password: Enter the password for the property ID or the provider.
- Click Save.
