Adding Dietary Labels to Menu Item Masters To configure and add dietary labels to menu item masters: Select the Enterprise or property level, click Configuration, and then click Roles. Double-click the employee record, and then click the EMC Modules tab. In the bulk operations list, scroll to the Dietary Labels row, and ensure the necessary operations are selected. Click Save. Select the Enterprise level, click Descriptors, and then click Dietary Labels. Add dietary label records as needed. If you delete a dietary label record, the system deletes all dietary labels associated with a menu item. The Use Template function is not supported in the Dietary Labels module. Click Save. Select the Enterprise level, click Configuration, and then click Menu Item Maintenance. Search for and then double-click the menu item master record, and then click the Dietary Labels tab. In the Dietary Labels section, click Add, and then click the ... button. Select the dietary label for the menu item, and then click OK. Repeat Steps 10 and 11 to add more dietary labels. Click Save. Parent topic: Menu Item Masters
