Configuring Secondary Printing
  1. Select the revenue center, click Setup, and then click Order Devices.
  2. Double-click a printer order device record, and then click the Options tab.
  3. Select the appropriate options that apply to secondary printing.
    Table 28-9 Secondary Printing Options
    Option Description
    16 - Print Secondary Items
    Select this option to allow this order device to print items sent from other printers as secondary items.
    17 - Broadcast Secondary Print Jobs to All Printers
    Select this option to send all items set to print at this order device to other printers to print as secondary items. Items print only at other printers that have 16 - Print Secondary Items enabled.
    18 - Print Secondary Printer Header
    Select this option to print the name of the printer from which the secondary items are being broadcasted.
    19 - Print Secondary Items in Red
    Select this option to print secondary items in red.
    20 - Suppress Blank Lines Between Secondary Items
    Select this option to remove extra line spacing between secondary items on order chits.
  4. Click Save.
