Configuring an Alpha-Numeric Keyboard The following steps describe how to configure an Alpha-Numeric Keyboard in the EMC: Select the property, click Setup, and then click Alpha-Numeric Keyboard. Insert a new record, selecting Regular Alpha-Numeric or Small Screen Alpha-Numeric from the template record drop-down list. Add a name for the record, and then click OK. In the list view, set the desired language from the Language drop-down list. Click the Options button, and then ensure that the Default keyboard for this language option is enabled. Double-click the record. In the Page Design module, add the buttons for the workstation: Popup Alpha Numeric Keyboard Cancel (to be able to exit in the workstation) Click Save. Parent topic: Keyboards
