POS Keyboard
POS Keyboards can replace the standard alpha-numeric and numeric keyboards on all workstation types with a modern looking version that is consistent across all workstations’ operating systems.
If multiple keyboards are configured, operators can rotate through them to select the one suitable for their task.
The POS keyboard includes shift and special character layouts and is available in light and dark themes.
Where to access POS Keyboard: Enterprise, Zone, Property, or Revenue Center | Setup | POS Keyboard
Role Access: POS Keyboard
Role Privileges: View, Edit, Add Override
Views: Form view
Figure 8-6 POS Keyboard Module — Configuration Tab
Table 8-31 POS Keyboard Configuration Tab
| Field | Description | Data Type |
Add Keyboard |
Adds record to Keyboard grid. |
Button |
Delete Keyboard |
Deletes selected record from Keyboard grid. |
Button |
Up |
Moves selected record up by one record. |
Button |
Down |
Moves selected record down by one record. |
Button |
Order number of record. Primary indicates the default keyboard displayed to the operator. The operator can rotate through all configured keyboards in the order indicated. If no record is configured, the legacy keyboard configuration is used. |
Primary and Integer |
Keyboard |
Select the Keyboard layout for the selected record. Select None to skip this record in the rotation. If None is selected for the Primary record, the legacy keyboard configuration is used. |
List Choice |
A Database Download is required on the Simphony workstations for the changes to take effect.
