Simphony POS Operations Running on Android Mobile Operating System
You can run Simphony on devices that have the Android mobile operating system. The Simphony POS Operations application operates in a similar way on an Android mobile device and a Microsoft Windows device. You can configure POS Operations using the EMC.
The UI is the same on all devices and workstations. Android devices have special requirements to consider, including deployment method, configuration requirements, and the procurement process.
The Oracle Restaurants Compatibility Matrix contains more information about supported workstation operating systems.
The Oracle Simphony Client Deployment Guide contains more information about configuring Android devices as workstations.
Related Topics
