Viewing and Editing Simphony Android Files
After installing Simphony on an Android device, you can use the Configuration Management Tool to view and edit certain files.
  1. Launch the Simphony application on the Android device.
  2. After the application loads, perform the following task on the Android device: On event (left swipe + right swipe + left swipe + tap + tap).
  3. Enter the code based on the six-digit number shown at the top, and then press Sign In. The Management Tool Home screen appears.
  4. The following table lists the options and actions you can perform.
    Table 8-32 Simphony Android Files
    Option Action
    View web.config.txt
    Press to view and edit the web.config.txt file
    View config32.web
    Press to view and edit the config32.web file
    View Log
    Press to view the EGateway Log
    View LogZone
    Press to view the LogZone_LoadHandlers.txt file, which is not editable
    Ping Server
    Press to view the Server Name or IP Address
    Delete DataStore
    Press to delete the DataStore database file and restart the application on the device
    Copy DataStore
    Press to copy the DataStore database file within the device
