Configuring Reservation Privileges
  1. Select the Enterprise, click Configuration, and then click Roles.
  2. Select the role type (manager and/or host), click the Operations tab, and then click the Guest Management subtab.
  3. Select the appropriate privileges for the manager and host. The following table summarizes the privileges associated with reservation functionality.
    Table 39-12 Reservation Privileges
    Option Number Privilege Name Allows the Employee to ...
    32006
    Greet Wait List Entry
    Greet a reservation request if the party arrives earlier than the time at which the reservation automatically moves to the Wait List
    32007
    Mark as No Show
    Mark a reservation request as a no-show if the guest does not arrive
    32010
    Add Reservation Entry
    Create a reservation request
    32011
    Edit Reservation Entry
    Edit an existing reservation request
    32012
    Cancel Reservation Entry
    Cancel a reservation request
    32013
    Approve Reservation Entry
    Approve a reservation that is requesting a date or time outside the acceptable or allowable timeframe
  4. Click Save.
