Creating Standard Table Touchscreen Buttons
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
- Double-click the page on which to define standard tables.
- On the Edit tab, select the page area on which to place the standard tables.
- Select Other..., and then select Dining Table.
- Move and adjust the table size on the page. You can increase the grid configuration on the page from 24 (default) to 48 using the Change Grid Size link.
- Repeat Steps 4 and 5 to create additional standard table buttons.
- Click Save.
