Configuring Standard Tables
- Select the revenue center, click Setup, and then click Tables.
- Select or enter information for the following fields.
Table 39-4 Tables Fields
Field Description Table Number (# symbol)
Enter a unique table number for each table in the revenue center.
Name
Enter a unique table name for each table in the revenue center. The table name entered here is used to identify checks unless option 18 - Use table object number instead of name on transactions is enabled in the RVC Parameters module.
The Name field is limited to 16 characters:-
All numeric
All alpha
Alpha and then numeric
Class
Select the dining table class, which defines the type of table.
See Setting a Dining Table Class for more information.
- Click Save.
