Configuring the ValueLink Service Charge Record
You must configure the following four service charge records
for use with the ValueLink Processor for gift card service.
ValueLink Activate
ValueLink Batch Activate
ValueLink Activation Return
ValueLink Reload
- Select the Enterprise, property, or zone, click Configuration, and then click Service Charges.
- Insert a record, name it ValueLink Activate, and then click OK.
- Double-click the record to open it.
- Select option 14 - Service Charge Used For Stored Value Transactions.
- Set other Service Charge fields and options as needed. Configuring Service Charges contains more information about the fields and options.
- Click Save.
- Repeat steps 2 through 6 to create the remaining three service charge records.
