Send KDS Handler Package to KDS Controllers
  1. Sign in to EMC.
  2. Click the Enterprise, Setup tab, and then CAL Packages.
  3. Select All from the CAL packages tree.
  4. Click the Deployment Schedules tab.
  5. Click the Add Deployment option.
  6. Click the down arrow under Choose CAL Packages to upload to access the drop-down list, select KDS Handler x.x.x, and then select [file name] for the version of Simphony you are upgrading to. The (xxx) refers to the version number.
  7. Ensure the Deployment Type is set to 2 - Specific Service Host from the drop-down list, and then click the ellipsis ‘…’ adjacent to the same setting.
  8. Select the workstation or server which is defined as the KDS Controller for your property, and then click OK to close the Select Specific Service Host list. Click OK again to close the CAL package selection window.
  9. Verify the Action to Take column shows Install, and then click Save.
    Your workstations or server should begin receiving the KDS Controller update immediately, or at the scheduled download time if one has been configured.
  10. If you have a backup KDS Controller, repeat all of the previous steps for that device.
