Printing a Memo Check Pick up a check that has menu items from multiple seats. Filter the check by the seat numbers for which you want to print the memo check. See Filtering a Check by Seat Number for instructions. (Optional) Tender the check using the guest’s payment method. Press the Print Memo Check function key. Parent topic: Seat Filtering and Memo Checks
