Beginning and Closing a Check
You start a transaction using a function key. You must have the privileges to begin a guest check and to begin a check by table.
You cannot start a check if there are open checks older than the Open Check Age Threshold, which is configured in the Control Parameters module of the Enterprise Management Console (EMC).Parent topic: Guest Checks
