Guest Lookup
The OPERA Connection Guest Lookup function allows you to view details about a guest in a single view. Depending on the configuration, with OPERA Connection you can select one or more guests to add to a check or seat.
  1. Click the Guest Lookup button.
  2. If POS Keyboard is enabled, select to search by room number, last name, or loyalty account. Enter the room number or at least the first two letters of the guest’s last name. A list of matches appears.
    Each match is displayed as:
    [Room Number] *
    [Last Name], [First Name] *
    Arrival: [date] – Departure: [date]
    Total Nights: [count]
    * If displayed in red, the guest is not allowed to charge to the room (No Post).
    To hide No Post guests, set the toggle switch at the bottom of the selection list to on. To include No Post guests in the list, set the switch to off.
    1. To view details about the guest, click the tile. The profile page includes the following information for the guest:
      Room number and name
      Number of days until departure
      Number of adults/children in the room
      Preferences such as allergies
      Packages with details
      Package Descriptor
      Package Code
      Package Valid From — To
      Consumption Status
      Messages
      Notes
      Guest Notes
      Reservation Notes
    2. If a check is open, click the Assign Guest to Check or Assign Guest to Seat button to associate the guest with the check or seat.
      Assigning a guest does not pre-authorize nor charge payment; it is simply a query through OPERA Connection to associate the guest’s room number and name on the check. To tender the check using OPERA Connection Room Charge, see Tendering with OPERA Connect Room Charge.
      If seat handling is enabled in the revenue center, you can assign a guest to a specific seat for more personalized service.
    3. If no check is open, click theBegin Check button (if configured) to begin a new check. You may be prompted for a Check Number, Table Number, or Check Name. The selected guest will be assigned to the new check.
