2 Compliance, Warnings, and Specifications
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) This device must accept any interference received, including interference that may cause undesired operation.
This equipment has been tested and found to comply with the limits for a Class A digital device pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment generates uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his own expense.
Caution: Exposure to Radio Frequency Radiation.
To comply with FCC RF exposure compliance requirements, a separation distance of at least 20 cm must be maintained between the antenna of this device and all persons.
Caution: Any Changes or modifications not expressly approved by the manufacturer could void the user's authority to operate the equipment.
Class A Digital Device: Wired Device
This Apparatus complies with class “A” limits for radio interference as specified in the Canadian department of communications radio interference regulations.
This Class A digital apparatus complies with Canadian ICES-003.
Waste Electrical and Electric Equipment (WEEE)
This marking shown on the product or its literature indicates that it should not be disposed with other household wastes at the end of its working life. To prevent possible harm to the environment or human health from uncontrolled waste disposal, please separate this from other types of wastes and recycle it responsibly to promote the sustainable reuse of material resources. Household users should contact either the retailer where they purchased this product, or their local government office, for details of where and how they can take this item for environmentally safe recycling. Business users should contact their supplier and check the terms and conditions of the purchase contract. This product should not be mixed with other commercial wastes for disposal. |
WARNING & CAUTION Is described as death, physical injuries, serious financial losses, and damage to data etc. that can be caused to the user. |
Do not connect multiple products to a single or faulty power outlet. Use only grounded power outlets that meet the industry standard. Noncompliance may cause electric shock or fire.
Only use authentic products from Oracle & BIXOLON. The company will not provide post-sale support for damaged or other quality issues that any fake (or refurbished) products may incur.
Do not excessively bend or strain the power cord. Securely push the power cord all the way into the power outlet lest it remain loose. Make sure to hold the cord tight when separating it from the power outlet. Do not remove the power cord while the product is in use. Noncompliance may cause electric shock or fire.
Keep small accessories or other packaging materials away from young children. Beware: choking hazard. Mishandling the product may incur injuries which may require seeking urgent medical attention.
Keep excessive liquids away from the power cord and outlet. If matter is smeared onto the power cords, wipe with a dry cloth. Noncompliance may cause electric shock or fire.
Do not allow the product to be damaged by heavy objects. Noncompliance may cause electric shock or fire.
If the product emits a strange sound, burning smell, or smoke, turn off the power immediately and unplug the power cord. If the product is dropped or its exterior is damaged, turn off the power immediately and unplug the power cord. Do not subject the product to shock. It may start a fire. It may damage the product.
Install the product in a well-ventilated area by keeping it a certain distance from the wall. The product installed in certain places such as where a lot of fine dust is generated, where the temperature is too high or too low, where there is a lot of moisture or water, and at airports or stations that are used continuously for a long time may suffer serious quality problems due to the influence of the surrounding environment. An increase in internal temperature may start a fire. Be sure to contact the place of purchase before installing the product.
Install the product in a fixed place preventing it from tipping over. When moving the product, turn off the power and disconnect all connected cables, including the power cord. It may damage the product.
Never independently disassemble, repair, or modify the product, as the warranty will become invalid. When repair is necessary, contact the original place of purchase.
Do not let any foreign substances enter the product. Do not place heavy objects, liquids, or metals on the product.
Table 2-1 Technical Specifications for the Oracle SRP-350PlusV Thermal Receipt Printer
| Feature | Description | ||
Printing Method |
Thermal printing |
Dot Density |
180 dpi (7dots/mm) |
Printing Width |
3-inch |
72 mm |
Roll Width |
3-inch |
79.5±0.5 mm |
No. of Characters per Line (Default Value) |
42 (Font A) ,56 (Font B) ,56 (Font C) |
Printing Speed |
Max. 400 mm/sec |
Receiving Buffer Size |
4K bytes |
Supported Interface |
Ethernet, Serial, USB (via OPOS) |
Adapter Voltage |
Input Voltage |
100~240 VAC |
Frequency |
50/60 Hz |
Output Voltage |
24 VDC |
Output current |
2.5A |
Environment Condition |
Temperature |
Operating: 0 ~ 40 ℃ Storage: -20 ~ 60 ℃ |
Humidity |
Operating: 10 ~ 80 % RH Storage: 10 ~ 90 % RH Paper excluded |
Life Span |
Mechanism Head |
250 Km |
Auto Cutter |
2,000,000 cuts |
Specifications are based on operation at normal temperature using designated paper on default settings. They are subject to change depending on temperature or printing level. Printing speed may become slightly slower depending on the data transmission speed and the combination of commands.Oracle Part Number and Description
Oracle Marketing Part Number: 7607100
Description: Bixolon SRP-350plusV autocut thermal receipt printer with serial, Ethernet, and USB interfaces, 3-foot Ethernet cable, and power supply
