1 Preface
The Epson TM-P80II Plus is a compact 3-inch (80mm) thermal receipt printer that features IDN over USB-C connectivity. The IDN over USB-C interface allows for direct connection from the printer to the Oracle workstation without requiring an external power supply. The compact design of the Epson TM-P80II Plus makes it the ideal solution for locations with limited counter space and access to power outlets.
The Epson TM-P80II Plus printer also includes multilingual fonts. This setup guide describes the unique features and setup required for operation specific to Oracle and multilingual printing from Oracle Food & Beverage point of sale applications. All multilingual fonts and Unicode command sets are now printer-resident and pre-loaded at the factory.
Audience
This document is intended for those who will set up, install, and operate the Epson TM-P80II Plus Thermal Receipt Printer.
Important Information
Additional information regarding integration with the POS system or other related software applications can be obtained from the respective application guides. The Epson User and Technical Reference Guide should also be referenced to understand the standard features of the printer.
The following product specifications and/or manual content may be changed by Oracle or Epson without prior notice.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL: https://support.oracle.com.
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to recreate
Exact error message received
Screenshots of each step you take
Documentation
Oracle Food and Beverage product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/food-beverage/
Epson TM-P80II Standard documentation is available from Epson’s website at:
Epson TM-P80II Installation Guide: https://files.support.epson.com/docid/cpd6/cpd62879.pdf
Epson TM-P80II Auto Cutter Model User Manual: https://support.epson.net/setupnavi/
Epson Technical Reference Guide: https://files.support.epson.com/pdf/pos/bulk/tm-p80ii_trg_en_revg.pdf
Epson Software Downloads
Epson P80II Auto Cutter Model Compatible Software components and the TM-P80II Utility can be downloaded at https://support.epson.net/setupnavi/?PINF=swlist&OSC=WS&LG2=EN&MKN=TM-P80II%20Auto%20Cutter%20Model
